Date/Time: Mon, 16 Nov 2026 23:44:44 +0000
What is the difference between these two currency pairs?
View Count: 974
| [2016-07-11 15:58:55] |
| User292365 - Posts: 20 |
Hello, I use CQG for data. I may have to contact them for this question... I figured I'd ask you because you guys first - you guys do a great job answering back! :) For the EURUSD, I see two symbols: F.US.EU6U16 and F.US.EEUU16 Both of these charts look the same. However, there is a difference in price. For example, as I'm writing this, the price for F.US.EEUU16 is 1.1072 and F.US.EU6U16 is 1.10710. What is the difference between both of these symbols? Is the price fluctuation $6.25/tick for each? Thanks! |
| [2016-07-11 17:49:50] |
F.US.EEUU16 is the E-MINI EURO/USD contract. For the Currency Value per Tick, refer to the Global Symbol Settings for the symbols: Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-11 17:50:51
