Date/Time: Mon, 16 Nov 2026 23:44:30 +0000
Drawing Lines
View Count: 950
| [2016-07-11 15:43:02] |
| gmorgan111 - Posts: 121 |
I have a problem with one of my charts. When I draw any type of line connecting the points on the candle like high or low I can not get the line to start at the end or top of the wick. The line always wants to start a tick away from where my click. How can I resolve this Thanks |
| [2016-07-11 16:46:31] |
What is the symbol of the chart?
| [2016-07-11 21:05:08] |
The symbol of the chart is 6CU6 The Canadian dollar Thanks |
| [2016-07-11 21:06:53] |
You need to update the Symbol Settings as explained here: Change to Minimum Price Increment for Canadian Dollar/U.S. Dollar (CAD/USD) Futures Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-11 21:07:03
