Date/Time: Mon, 16 Nov 2026 23:44:39 +0000
Daily OHLC missing parameters Sierra Charts Version 1441
View Count: 1870
[2016-07-11 12:12:00]
User360283 - Posts: 538
I want to display the High and Low Lines Incrementally for Day as per the documentation.
But the "Graph High Low Historically" study Input does not show.
Help please
[2016-07-11 16:26:05]
It must be there. We cannot think of a reason why you would not see it.
The Daily OHLC study has 12 Inputs. How many do you see for it?
[2016-07-11 17:36:31]
Only 6 inputs. See enclosed screen shot.
imagesiera daily ohlc.PNG / V - Attached On 2016-07-11 17:36:20 UTC - Size: 28.76 KB - 484 views
[2016-07-11 17:41:29]
This is not a Sierra Chart study.
You need to use the study with the exact name:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s137
[2016-07-11 17:56:19]
It is the Daily OHLC study. I added a short name so I could identify it more easily. How would that cause the inputs to change.
[2016-07-11 18:23:41]
OK we see that you are using the Daily OHLC-Single Point study. That one is different.
[2016-07-11 19:02:25]
Please see enclosed screen shots.
When I use the Daily OHLC single point:
What I am not understanding is why the Red Low Line is not extending from 2122 )the first yellow circle) to 2125 (the second yellow circle).
I am trying to create something like pivot channels.
When I use the Daily OHLC (not single point) and I set the Graph Open and Close Historically (Reference days back - 0) to Yes, I the green line is not a channel but tracks bar tops and the red line goes horizontal flat at 2122.75. I think it should have gone to 2125 and then to 2133
This does not look correct to me.
I was trying to achieve pivot channels
Help
imagesierra daily ohlc channels.PNG / V - Attached On 2016-07-11 19:01:56 UTC - Size: 60.93 KB - 432 views
imagesierra daily ohlc 2.PNG / V - Attached On 2016-07-11 19:02:18 UTC - Size: 98.98 KB - 392 views
[2016-07-11 23:25:51]
I have enclosed a pic of a Multi-charts Pivot Hi Lo channel. Note the pink lines. This is what I was trying to create with Sierra with the Daily OHLC or the OHLC. This was sent to me by another trader.
How can I get this to work with the straight channel lines in Sierra?
imagemulti pivot 3x3.PNG / V - Attached On 2016-07-11 23:25:45 UTC - Size: 63.08 KB - 470 views
[2016-07-12 06:05:25]
The images given in post #7 are completely unacceptable to us because they are too complex.
To provide a chart image, only use the method documented here:
Post an image of the chart showing what you see using the documented method.
We do not know what this is. Sierra Chart does not have this study and we do not know how this is calculated.
Date Time Of Last Edit: 2016-07-12 06:06:05
[2016-07-12 09:04:34]
I am trying to generate linear pivot channels using the Daily OHLC.
Enclosed are 2 pics.
The chart pic shows the non-straight lines generated by the Daily OHLC indicator. Note that they are not straight lines as I expected. I drew in straight lines like I thought would be generated.
Also, the lower line does not occur as frequently as I expected.
I also have included the study setting.
Is there a way to get the straight lines and the lower line to be generated as I expeted?
imagesiera daily ohlc settings.PNG / V - Attached On 2016-07-12 09:04:11 UTC - Size: 29.8 KB - 423 views
imagesiera daily ohlc.PNG / V - Attached On 2016-07-12 09:04:25 UTC - Size: 30.75 KB - 480 views
[2016-07-12 17:51:13]
Sierra Chart does not have a study that does this.
