Date/Time: Mon, 16 Nov 2026 23:44:33 +0000
Difference of Net Change STUDY error
View Count: 1036
| [2016-07-11 10:40:42] |
| Meritus - Posts: 164 |
Good morning, I am trying to build a chart of the Net Change between the CME UB and ZB futures using the Difference of Net Change study. However when I add the study the subgraph is blank as shown in the screenshot below. http://www.sierrachart.com/image.php?Image=1468233161132.png I have looked at the Show Study Description but there is no info on this study. Please advise if there is a better study to use or if I am applying it incorrectly. I attach the Message Log below Date Time Of Last Edit: 2016-07-11 10:51:30
| [2016-07-12 03:58:58] |
We are going to be documenting this study today.
| [2016-07-12 05:56:29] |
There was a problem in the study function for this study. It has been corrected and it will be out in the next release in a couple of days. Here is the updated documentation: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s342 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-12 05:56:54
