Date/Time: Mon, 16 Nov 2026 23:44:43 +0000
SC starting issues;
View Count: 1200
[2016-07-10 00:38:17]
@sstfrederik - Posts: 413
After windows update on my Windows server 2008 R2 I have issues with starting SC.
My previous SC installs will not start and crash. I downloaded the SC installer and installed the newest version in an existing directory.
When I select "Run program after Install Complete" SC starts fine. After I exit and restart SC, it will crash again.
I have the same issues with a fresh install.
Pls advise.
Date Time Of Last Edit: 2016-07-10 01:02:10
imagesc-crash.png / V - Attached On 2016-07-10 01:00:09 UTC - Size: 8.39 KB - 420 views
imagesc-crash-2.png / V - Attached On 2016-07-10 01:02:06 UTC - Size: 8.38 KB - 475 views
[2016-07-10 01:13:15]
If you are noticing this with a completely fresh installation of Sierra Chart into a new folder, almost certainly it is going to be some operating system related issue.
Not sure this would help, but install this redistributable package again:
http://www.microsoft.com/en-us/download/details.aspx?id=5555
[2016-07-10 01:17:50]
I have that installed already.
I have a new SC install working now. I copied my config and files in the data dir and it runs fine now. So I am back to normal.
Will do this for the other instances of SC as well.
[2016-07-10 01:20:26]
OK good.
