Date/Time: Mon, 16 Nov 2026 23:44:43 +0000
SaveChartImageToFile adds message to log and pops log message up
View Count: 1010
| [2016-07-08 16:55:49] |
| onnb - Posts: 666 |
We are getting message that says The chart image has been saved to: xxx.png Not a problem with the message itself but the Message Log also pops up. Can you 1. suppress popping it up all together 2. provide the user with an option to suppress it |
| [2016-07-09 22:31:07] |
1. We are doing this.
| [2016-07-10 03:56:12] |
| onnb - Posts: 666 |
What version to look out for this?
| [2016-07-10 04:14:27] |
1443.
| [2016-07-10 19:26:47] |
| i960 - Posts: 360 |
Thanks for doing this - I've also found the log popup to be annoying. I'm still waiting for that "suppress restoring the message log window" option to stop the message log from popping up in 100% of cases. Those of us with 1 monitor can't just move it away - and there are situations where things like continual IB historical pacing violations and "waiting to download in n seconds" keep popping it up which is extremely annoying. |
| [2016-07-10 22:17:57] |
We will make sure pacing violation messages do not cause the Message Log to open.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-07-10 22:18:14
| [2016-07-10 22:19:51] |
From what we can tell pacing violation messages will not open the Message Log. If they do, provide us those specific messages so we can examine them.
| [2016-07-10 23:14:07] |
| i960 - Posts: 360 |
What about the "will retry in <n> seconds" message?
| [2016-07-10 23:20:32] |
This message does not open the Message Log either: "Waiting n seconds for next download request." Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
