Date/Time: Mon, 02 Nov 2026 04:31:04 +0000
Candle Volume Price Bars, kinda
View Count: 3773
[2013-07-16 01:25:46]
User28682 - Posts: 233
The Candle Volume Price Bar will only really show a wide body if its volume is bigger than the previous biggest one on my chart. Other high ones with high, but slightly less volume dont get much credit. Does a tool exist in SC allowing me to get all wide candlestick bars for all higher volume trades over a threshold amount?
Thanks!
[2013-07-16 19:00:01]
No. This is not supported.
[2013-07-16 20:03:22]
Thanks, one big problem with its current format, is in the last 30 min of trade. As the day ends there is a natural surge in volume to close positions. This equates to wide candles, then no other nice sized candles can print wide. SC should consider something for ALL volumes over a threshold intead of just 1 big one, and then having to compare to that.
