Date/Time: Mon, 16 Nov 2026 23:54:23 +0000
Missing Release Notes for the last 5 Releases
View Count: 982
[2016-06-28 18:36:54]
Cavalry3162 - Posts: 523
Hello SC,
can you shed some light onto your 5 latest releases? what did you fix / add / change? i understand that you guys are busy but given how quickly you release atm. i guess it wouldnt be more than a couple of lines in the release notes and this would help us prerelease users quite substantially.. (do i need to update due to a bug fixed? should i wait due to some changes i am not sure could spoil my setup..)
thanks,
Andreas
[2016-06-29 02:16:35]
The release notes will be updated today. But only the major items are going to be mentioned.
Generally you would only want to update if you are using the Market Depth Historical Graph feature.
