Date/Time: Mon, 02 Nov 2026 04:31:07 +0000
Price/Chart on foreground
View Count: 2217
[2013-07-15 15:49:32]
ferasmu - Posts: 3
Good day,
I'm using V996 of Sierrachart.
Is there a way to get the main price chart/graph on the foreground, ie, in front of any studies applied to the chart?
[2013-07-15 16:37:05]
M5amhan - Posts: 468
when you go to your study settings where you input the parameters (tab settings and inputs) on the left hand side there is an option "draw study underneath main price graph" that if checked will plot underneath price
[2013-07-15 17:35:24]
ferasmu - Posts: 3
Thanks Trade2day1
Can't believe I missed it *facepalm
[2013-07-17 00:52:49]
In the Study Settings window for each of the studies you need to enable Draw Study Underneath Main Price Graph. For documentation, refer to:
https://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#DisplayStudyUnderMPG
