Date/Time: Mon, 16 Nov 2026 23:54:26 +0000
Enter a trade on 2 brokers at the same time
View Count: 1053
| [2016-06-25 07:43:36] |
| tradernikki - Posts: 41 |
I have 2 accounts at 2 different brokerage firms. Both of them support sierrachart. Can I use 1 DOM to enter a trade simultaneously to both accounts on 1 click? Regards, Nikki |
| [2016-06-25 08:13:50] |
No, this is not supported.
| [2016-06-26 09:14:17] |
| Cavalry3162 - Posts: 523 |
@SC, is it possible to do that with acsil? like a couple of sc instances and sync positions?
| [2016-06-26 21:56:39] |
We would think this would be possible using ACSIL but it is well outside the scope of our support as to the implementation details and how reliably someone could make it work.
| [2016-06-28 14:00:24] |
| User60287 - Posts: 21 |
Would Sierra Chart work with IB Advisor account?
| [2016-06-28 17:15:59] |
Yes but not perfectly. But certainly when you submit an order from Sierra Chart into an advisor account the order handling rules that you specify, will be followed by TWS. Our official position on it is stated here: Interactive Brokers Trading Service: Using Financial Advisor Accounts The problem is going to come with Position reporting, and fill handling and reporting. There can be various issues that you can encounter. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-28 17:16:32
