Date/Time: Tue, 17 Nov 2026 00:04:51 +0000
Problem with EUREX Data feed
View Count: 1263
| [2016-06-14 07:25:41] |
| JRA - Posts: 97 |
Is there any problem with EUREX Data feed. I am encountering problems with DAX Futures Feed from 09:10 CET
| [2016-06-14 07:27:41] |
We are checking on this.
| [2016-06-14 07:44:53] |
There is clearly a Barchart data problem. We are going patch in a different data feed, but that may take us up to 30 minutes.
| [2016-06-14 08:20:55] |
The EUREX data feed is now working. We apologize for the issue. It was a Barchart server data problem. They have been notified about it. We are using an alternate data feed at this time. We will make it clear to them, that they need to do a much better job and this is quite serious because this is the second time in recent months this has happened. There is going to be some incomplete data today for the EUREX due to the data problem. Follow the instructions here to re-download the data where there is incomplete data in the chart: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Retrying the Download When There is Data in the Chart If there is any further problem, let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
