Date/Time: Tue, 17 Nov 2026 00:04:36 +0000
Does this function exist?
View Count: 1282
| [2016-06-13 12:54:54] |
| infpz - Posts: 826 |
Would you happen to know if there is a way to configure a study to a button for quick/easy turn on/off. Kind of like switching between bar periods. I can click on a 30 min button and very quickly go to 5 min using another button. |
| [2016-06-13 16:30:01] |
No, this is not supported. However, refer to this section here for documentation on how to quickly hide and display a study: Chart Studies: Hiding and Showing Study Directly from Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-06-14 00:09:45] |
| User948528 - Posts: 108 |
+1 for this request.
