Date/Time: Wed, 14 Oct 2026 22:42:57 +0000
Put seconds in a text format
View Count: 1015
[2016-06-13 12:24:03]
User210074 - Posts: 63
I will want to implant in a text format a time variable: Seconds
#include <iostream>
#include <string>
#include <fstream>
#include "sierrachart.h"
using namespace std;
SCDLLName("Exemple");
SCSFExport scsf_Exemple(SCStudyGraphRef sc) {
if(sc.SetDefaults){
sc.Se="Sec : ";
   int Sec=GetSecond();
   sc.Se.Format("Sec : %02i",Sec);
    return;
ERROR
-- Starting build of Custom Studies Source files: Example.cpp. -- 14:14:14
"Z:\SierraChart\CPPCompiler\bin\g++.exe" "Z:\SC_Graphique_rithmic\ACS_Source\Example.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -std=gnu++11 -o "Z:\SC_Graphique_rithmic\Data\Example.dll"
Z:\SC_Graphique_rithmic\ACS_Source\Example.cpp: In function 'void scsf_Exemple(SCStudyInterfaceRef)':
Z:\SC_Graphique_rithmic\ACS_Source\Example.cpp:10:9: error: 'struct s_sc' has no member named 'Se'
sc.Se="Sec : ";
Z:\SC_Graphique_rithmic\ACS_Source\Example.cpp:11:21: error: 'GetSecond' was not declared in this scope
Z:\SC_Graphique_rithmic\ACS_Source\Example.cpp:12:6: error: 'struct s_sc' has no member named 'Se'
-- End of Build -- 14:14:16
I don't understand this error
[2016-06-13 16:27:37]
This line makes no sense:
sc.Se="Sec : ";
This function does not exist.
It should be:
SCString SecondsString = "Sec : ";
