Date/Time: Tue, 17 Nov 2026 00:04:50 +0000
Usage time remaining
View Count: 1319
| [2016-06-13 03:29:32] |
| User571345 - Posts: 3 |
Control panel says 19 days remaining, but the sierra log says usage time has ended. This isn't the first time this has happened.
| [2016-06-13 03:56:38] |
Is your computer's clock set correctly? Also you are running a significantly older version of Sierra Chart. Update following these instructions: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
