Date/Time: Tue, 17 Nov 2026 00:04:43 +0000
problem related to SC real-time data feed
View Count: 1087
| [2016-06-13 01:01:18] |
| johnz2016 - Posts: 10 |
Hi, I am a subscriber of SC real-time data feed. I encounter a problem related to my intraday chart. Please see the attached image. Even though I try to set the "from" field to an earlier date, such as 2014-10-1, it is always set to 2015-11-05 by itself. Is the real-time data feed supporting up to 3-years tick data at least? This is for ES. Beside, to save exchange fee, I sign in using TD Ameritrade account following the instructions on your website. Thanks! |
| [2016-06-13 08:21:16] |
Refer to the documentation for that setting here: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#DateRangeInFile We see you are using the Continuous Features Contract feature. If there is any missing data, refer to the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading Is the real-time data feed supporting up to 3-years tick data at least?
Yes for sure.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-13 08:21:49
