Date/Time: Tue, 17 Nov 2026 00:04:47 +0000
ERROR - Max # of retries encountered - in attempting to install 1427
View Count: 999
[2016-06-12 21:01:59]
User299392 - Posts: 216
I am getting this error in trying to down load the prerelease 1427
Please look into it as soon as you can. Please.
Will appreciate if you attended before Japan trading begins in 3 hours.
[2016-06-12 21:23:08]
Futurestrader77 - Posts: 126
Dear Support Team,
the installer cannot download the SierraChart.exe file ("Incorrect URL or problem with connection when trying to download SierraChart.exe file.").
Please see the attachment.
Best regards.
Date Time Of Last Edit: 2016-06-12 21:23:37
attachmentInstaller Log 2016-06-12 173946.log - Attached On 2016-06-12 21:21:12 UTC - Size: 5.08 KB - 565 views
[2016-06-12 21:29:49]
We are checking on this.
[2016-06-12 22:11:56]
First of all, we recommend using 1426.
There were a couple of problems relating to the installer. This is the reason for the problem. This is now solved. Try again following these instructions here:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
We apologize for the issue.
