Date/Time: Tue, 17 Nov 2026 00:04:45 +0000
Bar Period Linking Issuse
View Count: 1049
[2016-06-12 10:32:43]
User96015 - Posts: 55
Dear sir,
I have noticed an issuse about linking chart.
I have linked some charts with Bar Period, but type of bar period doesn' t change,
and it' s a problem if u have multiple charts to manage.
Thx.
Bye
[2016-06-13 04:36:18]
There cannot be a problem with Bar Period linking. We tested that and verified it again. Refer to the documentation here to make sure you are using it properly:
https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#LinkNumber
[2016-06-13 06:57:33]
Yes sir,
but if I change from Renko to Reversal Bar for exemple, SC doesn' t change anything.
Bye,
[2016-06-13 08:30:45]
We tested this and still do not see a problem. There simply should not be a problem with this.
Make sure the Bar Period Chart Linking option is actually enabled on the chart where you want the chart bar period to change.
