Date/Time: Tue, 17 Nov 2026 00:04:41 +0000
how do I scrunch/decrease the vertical size of the bars
View Count: 1544
[2016-06-10 20:56:59]
johnbougearel - Posts: 26
I can drag scale down but I lose bars that are at bottom of screen.
I need to scrunch the bars together to be narrower horizontal width, but how do I scrunch or decrease the vertical size of the bars?
[2016-06-10 21:33:19]
You need to use Interactive Scale Range:
Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale
Date Time Of Last Edit: 2016-06-10 21:33:34
[2016-06-13 15:55:46]
I have changed my chart log scales to linear, and checked the "move" box in the drop down menu found under chart>interactive scaling, but still can not change the vertical size of the bars.
I believe I will need remote support for this.
[2016-06-13 16:55:49]
You first need to select Chart >> Interactive Scaling Mode >> Range.
[2016-06-13 17:19:23]
oh thank god!
