Date/Time: Tue, 17 Nov 2026 00:04:34 +0000
Futures did not rollover automatically
View Count: 1224
[2016-06-10 14:43:55]
User299392 - Posts: 216
Despite Chart settings having - Automatic Rollover checked and Continuous Contract set as Date Rule Rollover, Back Adjusted - the futures did not roll automatically - any reason why?
Yes, one thing I can observe is that the application was not closed down overnight. Is that what it was? If so, at what time does it roll if the TimeZone = New York?
[2016-06-10 17:56:40]
There will not be an automatic rollover. It is only when a Chartbook is reopened will there be a rollover.
You need to do it manually. The documentation does explain this for those options mentioned.
Follow the instructions here to roll over the symbol:
Changing to a New Futures Contract Month
Date Time Of Last Edit: 2016-06-10 17:57:13
[2016-06-13 13:50:23]
Guys -
When I closed and opened the application last time to have the application perform automatic rollover - it changed all the start and end times too for all the intra day charts it performed automatic roll over - any reason if this is normal?
Is there a way - where you do not let the system change start/end times while still perform automatic rollover?
[2016-06-13 16:44:51]
To prevent this, refer to the documentation here:
Global Symbol Settings: Setting of Intraday Chart Session Times
