Date/Time: Tue, 17 Nov 2026 00:04:55 +0000
Adding ALERT SOUND to indicator
View Count: 1905
| [2016-06-09 15:35:44] |
| User497973 - Posts: 15 |
Hi, I'm looking to set up a simple SOUND ALERT for when price crosses above/below the Supertrend indicator. The indicator is found on Chart # 4, with an id of ID:2 I've tried going through the manual and have tried several formulas but it doesn't seem to make any sound when the price crosses the indicator. I've tried the following: =CROSSOVER(C,ID2) - didn't seem to work What is the correct formula to input in order to get this to work? Also, where do I input the formula? Under the alerts tab under the INDICATOR itself? or in the alerts tab under the Chart Settings? Thank You in advance, DS |
| [2016-06-09 19:36:10] |
The formula you will need to use is: = CROSSOVER (C, SG1) Set this formula directly on the study. Here are instructions: Study/Chart Alerts And Scanning: To Enter an Alert Condition on a Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-09 19:36:24
| [2016-06-13 18:24:48] |
Thank You! That worked.
