Date/Time: Tue, 17 Nov 2026 00:04:38 +0000
J7M6
View Count: 1076
| [2016-06-09 14:27:52] |
| infpz - Posts: 826 |
Connected to TA, do you see movement? Might be a symbol formatting issue.
| [2016-06-09 17:04:28] |
We are checking on this.
| [2016-06-09 17:56:19] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Follow the instructions here to update the symbol settings in the chart: Global Symbol Settings: Update/Apply Symbol Settings to Charts Re-download the data in the chart with Edit >> Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
