Date/Time: Tue, 17 Nov 2026 00:14:37 +0000
countdown timer not in sync?
View Count: 1084
| [2016-06-03 00:41:53] |
| User656410 - Posts: 12 |
Hello, My countdown timer is not in time with the candle on the chart. It can be anywhere from a few seconds to two minutes off. The timer will hit zero and the candle will still be moving. The candle and volume will change at the same time, but not the timer. Is there anyway to fix this? Thank you |
| [2016-06-03 02:30:08] |
This is explained here: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s201 The fastest solution is to select Global Settings >> Set System Date-Time from Server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
