Date/Time: Tue, 17 Nov 2026 00:14:35 +0000
Opening existing .cpp file in editor overwrites file with new file template
View Count: 954
[2016-06-02 19:30:43]
bobwest - Posts: 4
I am new to SC coding, and I found this behavior beginning yesterday or the day before:
1. Open an existing .cpp file via the menu: Analysis > New/Open Custom Studies File > select the file name
2. The file opens with nothing but the new file template containing the SetDefaults code. All the previously-existing code is gone. Checking in Windows File Manager, the old file has been overwritten.
For instance, this happened just now to the studies.cpp file. I have a backup, so no harm done, but apparently I can't open or edit any existing cpp file now. I am pretty sure that it worked as expected (just opened the file) before.
I upgraded to version 1422 today and it's still happening.
Is there some other way I should be accessing these files?
Thanks for your help.
Bob.
[2016-06-03 09:22:33]
We apologize for the delay. We are checking on this now.
[2016-06-03 10:28:49]
This will be corrected in version 1423.
It was a compiler error causing this unexpected problem.
