Date/Time: Tue, 17 Nov 2026 00:14:36 +0000
DTC subinstance service question
View Count: 995
| [2016-06-02 16:43:13] |
| User11942 - Posts: 298 |
Hello SC team, Why a local instance always downloads data files from remote instance (when using DTC subinstance as a trading service) for symbols that actually aren't requested by the local instance? Basically, it downloads all data files that the remote instance is tracking. It's about 20 GB of unwanted data being downloaded every single day. I have to delete all those files every time b/c I have a limited space on my laptop and downloading of that amount of data via WiFi/mobile bandwidth simply puts the connection down. Is there a way to fix that? Thanks. |
| [2016-06-02 17:28:33] |
You must have enabled Global Settings >> Data/Trade Service Settings >> SC Server Settings >> Auto Send Security Definition for New Symbols.
| [2016-06-02 17:31:55] |
This is actually explained at step 9 here: Data and Trading Communications (DTC) Protocol Server: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-06-02 17:38:03] |
Right, it was enabled. Thanks!
