Date/Time: Tue, 17 Nov 2026 00:04:42 +0000
Left Side Scale not working for constant range
View Count: 1214
[2016-06-02 15:22:20]
MonteCarlo64 - Posts: 23
In advanced settings I have checked use left side scale. I have one study in chart region 1 (cumulative delta bars-volume). With independent scaling I have the CDV scale on the LHS and ES price on the RHS. That is not what I want, but it is the only choice that uses the LHS scale for the CDV. When I select to scale the CDV as Constant Range I get the ES pricing on both sides! I can only get the last value to appear on the LHS by selecting it under the Study/Settings/Subgraphs tab for value label. I want the LHS scale to be for the CDV when using Constant range, which is supposed to work and worked in the past!
[2016-06-02 17:20:31]
The problem is the chart itself also has a constant range scale which causes it to work like this. So you need to use Automatic for the main price graph:
Chart Scale and Scale Adjusting
This is not something that we would change without very careful analysis which we do not have the time for now. There must be a reason why it works this way.
[2016-06-02 21:51:33]
We had a chance to look into this and apparently the reason for what you see is just a scenario that was not considered. And not a particular reason. So it will be solved in the next release.
[2016-06-03 12:56:05]
Thanks, it was working properly some time ago but I don't know when it stopped working properly. I need to be able to use constant range for both the ES chart and the CDV study so I can scale one to the other and then see divergence to detect responsive selling or responsive buying over an extended period of time. I was very disappointed by the first response but now pleased by your second response.
[2016-06-03 17:14:52]
This definitely would not have worked previously with the configuration you are using. Follow the instructions here to update Sierra Chart:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
