Date/Time: Tue, 17 Nov 2026 00:14:40 +0000
quote board changing first row contract after restart.
View Count: 954
[2016-06-02 13:52:31]
kinghat - Posts: 120
these screenshots are from the previous crude contract roll i just havnt gotten around to posting the issue yet. you can see that i had the CLM6 in the top row and CLN6 in the second row and after a restart it would change the top row 'CLM6' to the second row value of 'CLN6'. to date, if i change the first row back to CLM6, after a restart it will go back to the second row value.
imageSierraChart_2016-05-24_12-29-49.png / V - Attached On 2016-06-02 13:52:03 UTC - Size: 19.4 KB - 337 views
imageSierraChart_2016-06-02_08-51-25.png / V - Attached On 2016-06-02 13:52:13 UTC - Size: 15.97 KB - 346 views
[2016-06-02 16:51:03]
Uncheck Settings >> Automatically Rollover Futures Symbols on the Quote Board window.
[2016-06-02 17:01:32]
thanks for the tip!
another question for the quote board, is it a totally different window than the rest of SC because it doesnt show up in the win10 virtual desktop overview as seen in the attached pictures.
image2016-06-02_11-56-39.png / V - Attached On 2016-06-02 16:59:08 UTC - Size: 585.39 KB - 349 views
image2016-06-02_12-00-17.png / V - Attached On 2016-06-02 17:01:11 UTC - Size: 2.15 MB - 351 views
[2016-06-02 17:24:24]
This is not a question that we can answer.
There are going to be some differences relating to the different attributes of a window but we do not know why you see what you do, whatever that is.
[2016-06-02 19:13:35]
are you able to see a quote board when using the task view in win10?
imagechrome_2016-06-02_14-12-55.png / V - Attached On 2016-06-02 19:13:30 UTC - Size: 3.47 KB - 320 views
[2016-06-02 19:20:52]
We do not use Windows 10 and if you need help with Windows 10 you need to rely upon Microsoft support.
The quote Board should display properly on all Microsoft Windows versions.
