Date/Time: Tue, 17 Nov 2026 00:14:36 +0000
Trading DOM | Inside Bid & Inside Ask are blocked by red and green cubes.
View Count: 1927
| [2016-06-02 12:32:08] |
| TapeReader - Posts: 101 |
In the attached graphic the inside Bid & inside Ask are blocked by red and green cubes. How can these be removed? Thanks. |
| [2016-06-02 16:56:57] |
You need to uncheck this option on Global Settings >> Chart DOM Settings: https://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#DisplayVolBarForBidAskSizes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
