Date/Time: Tue, 17 Nov 2026 00:14:35 +0000
LMAX demo data - lag in price between different charts of EURUSD
View Count: 1701
| [2016-06-02 12:29:58] |
| Zosimus - Posts: 345 |
Hi SC team, I'm testing the LMAX data using the demo server and I see a lag in price in different charts of EURUSD. I have only 5 charts in this chartbook. 4 of EURUSD ans one of TICK. Also everything is working very slow with the LMAX data. I removed all my custom studies from the charts but the problem persists. Image attached. Here is the Log: Software version: 1420 | 2016-06-02 08:30:59 Uses New Spreadsheets | 2016-06-02 08:30:59 Usage end date: 2016-07-04 | 2016-06-02 08:30:59 Enabled for: Advanced Features. | 2016-06-02 08:30:59 Enabled for: Advanced Features 2. | 2016-06-02 08:30:59 Enabled for: Sierra Chart Historical Data Service. | 2016-06-02 08:30:59 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-06-02 08:30:59 Current selected Data/Trading service: LMAX Demo Trading - DTC | 2016-06-02 08:30:59 Chart Update Interval: 200 | 2016-06-02 08:30:59 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-06-02 08:30:59 2016-06-02 15:31:01 Local computer time | 2016-06-02 08:30:59 2016-06-02 12:31:01 Local computer time in UTC | 2016-06-02 08:30:59 2016-06-02 08:31:01 Local computer time in SC Time Zone | 2016-06-02 08:30:59 2016-06-02 12:01:00 Server time in UTC | 2016-06-02 08:30:59 Local computer UTC time and Server UTC time difference: 1 seconds. | 2016-06-02 08:30:59 Program path: C:\SC_Optimus_NoCLR\ | 2016-06-02 08:30:59 Data Files path: C:\SC_Optimus_NoCLR\Data\ | 2016-06-02 08:30:59 OS Version Number: 6.2 | 2016-06-02 08:30:59 Locale Setting: C | 2016-06-02 08:30:59 Unsubscribed from market depth data for EURUSD | 2016-06-02 08:31:30 EURUSD [C] Rev. 5t #18 | Reloading chart. | 2016-06-02 08:31:34 EURUSD [C] Rev. 5t #18 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2016-06-02 08:31:34 EURUSD [C] Rev. 5t #18 | There are no continuous futures contract symbols. Loading data normally. | 2016-06-02 08:31:34 Notice: The study 'TickOnChartSource' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2016-06-02 08:31:34 TICK-NYSE 2 Min #1 | Reloading chart. | 2016-06-02 08:31:34 ESM6-CME [C] 2 Min #13 | Reloading chart. | 2016-06-02 08:31:34 ESM6-CME [C] 2 Min #13 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2016-06-02 08:31:34 ESM6-CME [C] 2 Min #13 | There are no continuous futures contract symbols. Loading data normally. | 2016-06-02 08:31:34 EURUSD [C] 30 Min #14 | Reloading chart. | 2016-06-02 08:31:34 EURUSD [C] 30 Min #14 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2016-06-02 08:31:34 EURUSD [C] 30 Min #14 | There are no continuous futures contract symbols. Loading data normally. | 2016-06-02 08:31:34 EURUSD [C] 2 Min #15 | Reloading chart. | 2016-06-02 08:31:34 EURUSD [C] 2 Min #15 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2016-06-02 08:31:34 EURUSD [C] 2 Min #15 | There are no continuous futures contract symbols. Loading data normally. | 2016-06-02 08:31:34 EURUSD [C] Rev. 5t #17 | Reloading chart. | 2016-06-02 08:31:34 EURUSD [C] Rev. 5t #17 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2016-06-02 08:31:34 EURUSD [C] Rev. 5t #17 | There are no continuous futures contract symbols. Loading data normally. | 2016-06-02 08:31:34 Notice: The study 'TickOnChartSource' has sc.FreeDLL set to true. Use only during development! Set to false to reduce CPU time. | 2016-06-02 08:31:34 TICK-SP 2 Min #20 | Reloading chart. | 2016-06-02 08:31:34 NISS-SP 2 Min #3 | Reloading chart. | 2016-06-02 08:31:34 Requesting market depth updates for: EURUSD if supported. | 2016-06-02 08:31:46 LMAX Demo Trading - DTC | Clearing market depth for EURUSD. | 2016-06-02 08:31:46 Date Time Of Last Edit: 2016-06-02 12:32:51
| [2016-06-02 12:36:59] |
Sorry, problem solved. The charts were set to be continuous by mistake. Once I cancelled that everything seems to be ok. |
| [2016-06-02 16:43:57] |
That will not change the original problem. That makes no sense as being a cause. Also everything is working very slow with the LMAX data.
Refer to help topic 30:https://www.sierrachart.com/index.php?l=helpdetails30.html Also refer to: LMAX Trading Service: Differences Between LMAX Live and Demo Data Feeds Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-02 16:44:51
