Date/Time: Tue, 17 Nov 2026 00:14:38 +0000
Message Log
View Count: 951
| [2016-06-02 08:00:36] |
| nicktrader - Posts: 817 |
Why do I get these messages F.US.DDM16 [C] 35 Trades #7 | Performing a full recalculation because it has been tagged. Chartbook: 000 CB M5 + Tick.cht | 2016-06-02 09:49:24
Failed to open the file C:\SierraChart\Data\GER30.2016-06-02.depth for reading. Windows error code 2: Das System kann die angegebene Datei nicht finden. C:\SierraChart\Data\GER30.2016-06-02.depth | 2016-06-02 09:49:25 * Failed to open the file C:\SierraChart\Data\F.US.DDM16.2016-06-02.depth for reading. Windows error code 2: Das System kann die angegebene Datei nicht finden. C:\SierraChart\Data\F.US.DDM16.2016-06-02.depth | 2016-06-02 09:49:39 * Failed to open the file C:\SierraChart\Data\F.US.DDM16.2016-06-02.depth for reading. Windows error code 2: Das System kann die angegebene Datei nicht finden. C:\SierraChart\Data\F.US.DDM16.2016-06-02.depth | 2016-06-02 09:49:40 * Failed to open the file C:\SierraChart\Data\F.US.DDM16.2016-06-02.depth for reading. Windows error code 2: Das System kann die angegebene Datei nicht finden. C:\SierraChart\Data\F.US.DDM16.2016-06-02.depth | 2016-06-02 09:49:42 * All charts are open and all work correctly. |
| [2016-06-02 08:32:20] |
This problem has been solved. Update Sierra Chart with Help >> Download Current Version.
