Date/Time: Tue, 17 Nov 2026 00:04:40 +0000
What OPEN price does Sierra Charts use for BTC (Bitcoin)
View Count: 2134
[2016-05-31 21:26:23]
User733502 - Posts: 46
Seems the system defaults to local machine time
[2016-05-31 22:18:28]
What specific symbol? So that we can check on this.
[2016-05-31 22:26:20]
BTC-BSTMP
Also
ETH-BITFINEX
Thanks!
[2016-06-01 10:59:36]
The exchanges for these symbols do not provide an Open price. Therefore, the opening price you see is simply not accurate and the reset time is not predictable or stable.
This will be solved next week and the Open will reset at 0:00 UTC time.
[2016-06-01 20:35:04]
That makes sense
Thanks SC!
[2016-06-10 16:13:47]
HI SC
Will you be offering the ETH/BTC cross? This is where the bulk of the volume is currently trading. Also, my data for BTC and ETH is delayed, how can I get this data realtime?
Appreciate the support!
[2016-06-10 18:18:52]
From what exchange are you interested in getting data from this particular symbol from?
What is the exact symbol that you are using?
[2016-06-10 18:27:27]
Hi SC
I'm on your data feed.
I use Poloniex and know Kraken, Gemini offer it but probably others too
Currently using:
BTC-SSTMP
ETHUSD-BITFINEX
Would like to see ETH-BTC
[2016-06-10 19:30:21]
The symbol ETHBTC-BITFINEX has now been added.
You will then see it listed in File >> Find Symbol.
[2016-06-10 20:59:57]
Thanks SC!
The symbol came up but the Download failed.
I'm using the SC Data service
[2016-06-10 21:21:39]
We had to do some updates on our other servers. This is now done.
Reconnect to the data feed now through the File menu, and you will receive the data for that symbol.
[2016-06-10 21:42:03]
Awesome!
You are the best!!
Enjoy the weekend
* will there be more historical for ETH-BTC and ETH or does it have to build over time?
[2016-06-10 21:42:59]
We will see if we can easily import more data for it.
Right now there is not any further data available.
[2016-06-10 21:43:46]
ok Thanks for checking
