Date/Time: Tue, 17 Nov 2026 00:14:39 +0000
Cannot compile a file outside of \ACS_Source
View Count: 1233
[2016-05-30 06:06:12]
User754985 - Posts: 109
It is possible to select an ACSIL file in a folder different from \ACS_Source in the "Analysis/Build..." dialogue.
However, even if you "open" the selected file (e.g. in a sub-directory of \ACS_Source), the compiler still searches for the *.cpp file in \ACS_Source and states that such file "is missing".
this is in v1420.
[2016-05-30 06:46:06]
No, this is not supported.
[2016-05-30 06:59:26]
But that's the currently existing dialogue...which gives the impression that it works...
[2016-05-30 07:12:56]
It is not supported.
[2016-05-30 07:26:29]
I understood. But it is misleading your users..
Why have it?
[2016-05-30 08:02:20]
Why have what?
[2016-05-30 18:56:49]
Why give users an impression (buttons "Folder" and "open") that they can select a file in any location for compilation/building, if this feature is not working?
I had a strange situation where I had my ACSIL study in a \ACS_Source and then for the final release created a sub-folder \ACS_Source\Final, copied the *.cpp file there and made some final changes to it. But when I built it, i did not see the changes applied! And whatever i changed, it still remained at the "development" version..
After several of such trials, i accidentally noticed that compiler actually still builds from the \ACS_Source...
And after testing that this indeed does not work, decided to write to you.
[2016-05-30 19:22:53]
In the next release, we will remove the button from the Advanced Custom Study source file Open File window to change the folder.
Date Time Of Last Edit: 2016-05-30 19:23:08
