Date/Time: Tue, 17 Nov 2026 00:14:35 +0000
Background Coloring of High Volume in Numbers Bars
View Count: 1101
| [2016-05-29 20:41:12] |
| User434078 - Posts: 1 |
I'm looking for a convenient way to set up a numbers bar study so that the background color highlights each price in a numbers bar whenever the volume of contracts traded at that price in a particular numbers bar exceeds a specified volume (e.g., make the background of that price level change to cyan if the volume of ES contracts traded at the bid plus the volume of ES contracts traded at the offer in a numbers bar exceeds 10,000 contracts). I know how to bold the text to highlight a high volume price cell, but not how to change the background color. I'm a SC newbie, so it's certainly possible I am missing something basic, but I've searched the user manual and this forum to no avail. Thanks for any help on this issue. |
| [2016-05-29 23:00:52] |
You need to set the Column 1 Compare Thresholds to compare to actual values: http://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#ColumnCompareThresholds Here is the documentation for the Color Inputs and Background Coloring Method which will accomplish what you want: http://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#VolumeTradesPercentage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-29 23:01:13
