Date/Time: Tue, 17 Nov 2026 00:14:42 +0000
How to set up Number Bars?
View Count: 1807
[2016-05-29 06:19:24]
User589327 - Posts: 2
Referring to following linked image, I want Order Flow chart to display like that, which study should I apply? or do I need to customize the setting?
Moreover, if I want to load the ES order flow charts, under Data/Trade Service Setting, do you have any suggestions on which Service I should select for ES?
Furthermore, the Message Log is very annoying, do you have any suggestions on how to remove it?
Do you have any suggestions?
Thanks, to everyone very much for any suggestions :>
http://www.orderflows.com/wp-content/uploads/2016/03/Understanding-Delta.png
[2016-05-29 09:50:54]
We answered your questions here:
New for Sierra Chart
We need to understand specifically what the problem is with the Message Log. We do not know what you are referring to. It definitely cannot be removed. If it displays, then there is important information being communicated. This is by design.
Date Time Of Last Edit: 2016-05-29 09:51:26
