Date/Time: Tue, 17 Nov 2026 00:14:41 +0000
won't start after upgrade
View Count: 954
| [2016-05-29 02:18:18] |
| User398249 - Posts: 4 |
updated from 1414 to 1420. windows 10. now when trying to start SC, i get a window that says can't start this app
| [2016-05-29 05:43:55] |
Apparently the download of the files failed and there is an incomplete download. We will make sure that this kind of condition does not result in this kind of problem. Run the installer again: https://www.sierrachart.com/downloads/SierraChartFileDownloader.exe Install into this folder: C:\SierraChart\ Let us know if you have any more problems. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
