Date/Time: Tue, 17 Nov 2026 00:14:29 +0000
sc.ChartWindowHandle(chart_number)
View Count: 1032
| [2016-05-27 20:42:59] |
| onnb - Posts: 666 |
Is there a method to retrieve the window handle of a remote chart using the chart number? If not, would you be able to add one? |
| [2016-06-02 07:28:38] |
We will see about adding this.
| [2016-06-03 00:17:19] |
This will be out in the next release.
