Date/Time: Tue, 17 Nov 2026 00:14:28 +0000
Monthly Pivots
View Count: 1246
| [2016-05-27 18:08:30] |
| User80120 - Posts: 6 |
When I plot the monthly pivots on a blank chart than it's ok, but it will not plot when I have other indicators (sma's , ema's etc.) on the chart !? What can I do when I can't move the chart up/down or to crunch it with the mouse? how to fix this reoccurring problem? Thanks |
| [2016-05-27 20:41:31] |
It does not make sense that the Pivot Points-Variable Period study does not display when there are other studies on the chart. Possibly though the lines are not within the current view. You need to use Interactive Scale Move to move the chart up and down to see the lines: http://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#InteractiveScalingMoveUpDown You should have no trouble with Interactive Scale Move. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-27 20:42:03
| [2016-05-27 21:27:33] |
I agree, it makes no sense but unfortunately for me this is the case, and btw. I'm able to scroll the chart as high and low as I want but the pivots "don't" show up! Please advise, Thanks |
| [2016-05-27 21:57:41] |
Make sure the Scale Range for all of the studies and the main price graph is set to "Automatic". Refer to: http://www.sierrachart.com/index.php?page=doc/doc_Scaling.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
