Date/Time: Tue, 17 Nov 2026 00:14:36 +0000
What happened to all the indicators?
View Count: 945
| [2016-05-27 17:25:42] |
| User417726 - Posts: 9 |
I downloaded the new version 1419 and none of the standard indicators worked in my chartbook(Stochastic, RSI, etc). I checked the list of indicators/studies and the entire list was gutted. Anyone knows what happened? Trying to get filled in Thanks |
| [2016-05-27 19:40:05] |
Run the installer again, with Help >> Download Prerelease and make sure you exit from Sierra Chart when the installation begins.
| [2016-05-29 09:19:30] |
I downloaded the pre-release and still having the same issues. I went and downloaded 1406 version instead and it works great. Whats happening with the new updates?
| [2016-05-29 09:39:24] |
The new versions are just fine. There is absolutely no doubt that this is a system specific issue on your side. Exit from Sierra Chart and delete the SierraChartStudies.dll file in the Sierra Chart folder. After that, run the installer again: https://www.sierrachart.com/downloads/SierraChartFileDownloader.exe If you still have a problem, then there is an issue with maybe security software on your computer interfering with the Sierra Chart installer. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-29 09:52:26
