Date/Time: Tue, 17 Nov 2026 00:14:33 +0000
New Chart based on data columns from Spreadsheet System/Alert as X-axis
View Count: 888
[2016-05-27 16:01:17]
hft168 - Posts: 31
Hi S.C. Support,
Is there any way (like some basic Excel features)that we could use columns "O" and other formula columns generated data as the horizontal axis (X) to for a new chart with the respective price data?
For Example, in column "O", we have a calculation of inverse of time in unit of seconds (with zero second at cell O1002), in reference to 1000 rows of time (Column "A") and price data (Columns B,C,D,or E).
What is the best way to generate a chart that uses column "O" data as X-axis, and any/or all columns B,C,D,E as the Y-axis?
It there is no such feature now, will Sierra Chart consider adding a Study for that? (A study that a user can define the data set by calling a SG number in a Spreadsheet System/Alert)
Please advise, thank you.
[2016-05-27 20:08:45]
You can do this using the Advanced Custom Study Interface and Language:
http://www.sierrachart.com/index.php?page=doc/AdvancedCustomStudyInterfaceAndLanguage.php
Specifically refer to:
http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scIsCustomChart
We possibly could support this with the Spreadsheet study. However, the Date and Time of bars would have to be in column K.
