Date/Time: Tue, 17 Nov 2026 00:14:30 +0000
VbP study using single price increments on TPO chart?
View Count: 1010
| [2016-05-27 15:57:00] |
| kinghat - Posts: 120 |
is it possible to set the VbP study to use single price increments '1' when the TPO chart is using a value of '3'?
| [2016-05-27 19:06:57] |
No it is not.
| [2016-05-27 19:12:27] |
is it possible for you guys to add this functionality? the reasoning is that when you are using the TPO price increment for the VbP study it can give an awkward POC reading. although it is the correct POC reading per the study it might not be the actual POC for the day on a price increment set to 1.
| [2016-05-27 19:40:28] |
No one else has asked for this. There is insufficient demand for it. It also doubles the memory use of these types of charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
