Date/Time: Tue, 17 Nov 2026 00:14:28 +0000
Sub-instance re-downloads Symbol settings instead of copying from parent folder
View Count: 974
| [2016-05-27 12:28:59] |
| phaedonk - Posts: 352 |
Please change it so it copies the existing Symbol settings. I have made changes to rollovers (some are not even defined in the original), and the way it is designed messes up the back-testing. I tried overwriting the file, but the changes only occur with a restart. However, when I restart it re-downloads (?) the settings, over-writing mine once again. |
| [2016-05-28 08:49:01] |
We will add an option to support this in the Global Symbol Settings window, in the next release.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-28 08:49:24
| [2016-05-28 09:34:53] |
Actually we take back what we said in the prior post. Even though we added that option , it was a waste of time because it does not work properly. We cannot support what you are looking for. Please do not ask us about this right now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
