Date/Time: Tue, 17 Nov 2026 00:14:35 +0000
Open Interest with Rithmic Data feed
View Count: 1516
| [2016-05-27 00:00:34] |
| sigmadict - Posts: 95 |
Hello, I am using Rithmic data feed. I read on the board that the Open Interest on Intraday Chart is the number of trades per bar and not the actual Open Interest, that is out at the end of the day. Is it possible to get the actual Open Interest Data with Rithmic data feed with an Historical Daily Chart open ? Or, we need to switch feed to Sierra Chart historical data to get this information ? Thanks Regards |
| [2016-05-27 19:29:45] |
Refer to the documentation for the Open Interest study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s10 You will be able to get this data when using Rithmic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
