Date/Time: Tue, 17 Nov 2026 00:14:30 +0000
streaming data connection
View Count: 1459
| [2016-05-26 14:10:28] |
| User106463 - Posts: 4 |
Hello, I have set everyhing to SC Data All services, but have no live streaming. Can you help me? Thanks.
| [2016-05-26 16:27:13] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: Is Historical and Real-time Data Included? Sierra Chart Support |
| [2016-05-27 07:03:51] |
I trade futures indices - NQ and testing Fdax. Thanks
| [2016-05-27 13:33:13] |
Do you have a futures trading account? If so, with what broker/trading service? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-27 18:12:29] |
Yes, I have trading account, my broker is Striker.
| [2016-05-28 04:17:24] |
We apologize for the delay. We are not familiar with Striker and we want to give you a complete and proper answer. Do they use any of these trading platform systems listed here: https://www.sierrachart.com/index.php?page=doc/Data.php#Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-29 16:50:49] |
Yes, they use Rithmic.
| [2016-05-30 07:08:32] |
You can use your Rithmic account by following the setup instructions on this page here: Rithmic Trading Platform Service Or you can use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed However, to take advantage of the lower-priced CME exchange fees, you need to be using Rithmic or another supported trading platform service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
