Date/Time: Tue, 22 Sep 2026 16:31:46 +0000
intraday and historical chart
View Count: 2532
| [2013-07-11 20:53:13] |
| tomtom - Posts: 53 |
why are the daily intraday and historical charts so often different Daily chart of yesterday is wrong using SC forex Data FXCM thanks |
| [2013-07-11 23:21:31] |
Different in what way? See notes for version 950: http://www.sierrachart.com/index.php?l=doc/Whats_New.php#SCVer950 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-12 08:23:39
| [2013-07-11 23:53:12] |
| Kiwi - Posts: 375 |
Are both starting and finishing on the same hours? When my intraday day is different to end of day day then things get messed up. Date Time Of Last Edit: 2013-07-11 23:54:07
| [2013-07-12 07:18:15] |
Hello, different in that way that historical new candle start before day ending at 23:59:59 using SC 988 everything is set up correctly like in the Page written both starting and finishing 00:00:00 - 23:59:59 although can not change historical start and end time, its inactive because there ist no intraday available Most Days corrected an end of day , but some days just not like the day 10 to 11 this week, had noticed that new historical candle started to early before day ended then waiting of corrected, delete and download data in chart settings, but nothing changed EURUSD july 10 historical daily high = 1,29856 intraday high = 1,30244 |
| [2013-07-17 21:05:51] |
Historical Chart EURUSD Daily July 10 high July 11 low is still incorrect |
| [2013-07-17 22:02:29] |
Historical daily bars do not follow session times from 0 to 23:59:59. They are different and cannot be changed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2013-07-18 09:59:05] |
yes i now, but the bars are still wrong , so someone have to fix the data
| [2013-07-18 10:26:04] |
We cannot help with this. We have no control over the session times of historical daily data and there is nothing to fix. These are formed according to well-established standards by the providers of the data.
