Date/Time: Tue, 29 Sep 2026 08:04:10 +0000
Using the s_TimeAndSales structure with LMAX data
View Count: 986
| [2016-05-24 23:34:22] |
| Zosimus - Posts: 345 |
Is it possible to use the s_TimeAndSales structure with the Forex and CFD data of LMAX?
| [2016-05-25 00:14:12] |
Yes it is.
