Date/Time: Tue, 17 Nov 2026 00:14:33 +0000
Result=sc.BuyOrder/sc.SellOrder for non-Market orders
View Count: 1080
| [2016-05-24 22:59:37] |
| User754985 - Posts: 109 |
I have discovered by experience that if OrderType is other than the "Market", then in case order placement was successful, the Result=sc.BuyOrder(NewTargetOrder) will show either positive OR NEGATIVE quantity of successfully submitted order. I first found this out for OCO orders, and then Limit and Stop. What puzzled me also is that in case OrderType=LIMIT, the successfully submitted sc.SellOrder, will generate a positive result. What is the logic? |
| [2016-05-24 23:02:18] |
That was in contrast to what SC manuals say (function) Returns: A return value > 0 indicates the order was successfully submitted. If the value is > 0, then this value indicates the quantity of the submitted order. If the return value is negative, < 0, the order submission was ignored. |
| [2016-05-25 03:07:42] |
The documentation is correct. If the value is negative, there has been an error. This is definitive. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-25 04:13:58] |
I can see orders placed, open, modified, filled/cancelled as they should...There does not seem to be an error. This is for Stops/Limits/OCO_LIMIT_STOP...I did not check the other ones.. |
| [2016-05-25 04:21:44] |
We remain very adamant that the documentation is correct. We verified the code and determined that it is correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-25 04:22:25
