Date/Time: Tue, 29 Sep 2026 08:04:00 +0000
new issue on 1416 build
View Count: 983
| [2016-05-24 20:14:25] |
| User20450 - Posts: 330 |
hey nothing has changed on my charts and im getting this message on log , and a lag on chart saying calculating studies , let me know please , thanks
| [2016-05-24 22:50:54] |
This is a message from the CQG Web API server. We really do not understand why it occurs. There is nothing we can do about it from our side. If you are noticing continuous recalculations of studies, that is completely unrelated. In this case refer to help topic 30: http://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.3 http://www.sierrachart.com/index.php?page=doc/helpdetails30.html#h30.7 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-25 00:48:29] |
ok just strange first time im seeing it 2 min after new install , but thanks
