Date/Time: Tue, 29 Sep 2026 08:04:11 +0000
Two study overlays from one source of data
View Count: 853
| [2016-05-24 17:55:29] |
| User35326 - Posts: 57 |
SC: Will it be ok to have one chart that is 30 minutes, for example, that obviously would have studies on it and then have a 5 minute and a 15 minute chart in the same chartbook; and, use the study/price overlay study on both the 5 min. and the 15 min. charts that access the same original study on the 30 min. chart. In other words, would it cause any problems with unreliable data, or any other problems for that matter, if both the 5 minute and the 15 minute charts are pulling the same information from the same study on the single 30 minute chart? Thanks in advance and good trading to you. |
| [2016-05-24 18:04:28] |
This will work fine as described.
