Date/Time: Tue, 29 Sep 2026 08:04:04 +0000
User Contributed Study
View Count: 1807
| [2016-05-23 20:51:55] |
| User332203 - Posts: 20 |
I see a study in the User Contributed section named the Hilbert Sine Wave. I have used a similar study to this in ThinkOrSwim named the MESA Sine Wave. I would like to be able to see the source code for the Hilbert version to see if it is the same thing. Is it possible to get the source code for a user contributed study? Thanks |
| [2016-05-24 04:02:05] |
Yes all of the source code can be found here: User Contributed Advanced Custom Study System Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
