Date/Time: Tue, 29 Sep 2026 08:03:27 +0000
Option Symbols Format
View Count: 945
| [2016-05-23 13:52:38] |
| User713273 - Posts: 409 |
Hello - I have added index stock IWM to my list of trade able equities. Are you familiar with "Error No -5 ". I have had no such issues transitioning to other equities. Chart: IWM [M] 1 Min #2 | Study: Option Trader | Error in opening order, Bar No 392 Symbol IWM-OPT-20160527-111-C-SMART-100-USD Error No -5 | 2016-05-23 06:32:32 |
| [2016-05-23 18:19:12] |
This particular error comes from a custom study on the chart. So we do not know what it is. You need to check the source code of your study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
