Date/Time: Tue, 29 Sep 2026 08:03:32 +0000
[User Discussion] - AskV-BidV & AskV+BidV Alerts
View Count: 1174
| [2016-05-23 11:39:22] |
| Crudeoilist - Posts: 18 |
Dear Sir/Ma'am, How do I go about creating an alert for the following conditions. Not after the bar is finished but as the orders come in. Alert 1 AskV-BidV = 200 AskV+BidV = 1000 Alert 2 AskV-BidV = -200 AskV-BidV = 1000 Thanks in advance V Date Time Of Last Edit: 2016-05-23 15:29:18
| [2016-05-23 18:09:35] |
For the first one you need to use a Simple Alert Condition Formula on the chart: http://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php#EnterAlertOnMainPriceGraph The formula is: AV - BV = 200 From the above you can easily determine how the others should be done. All of the base graph identifiers are documented here: http://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php#BaseGraphIdentifiers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-05-24 11:24:49] |
Thank you, managed to get the alert working. However, I can only get 1 condition working. How can I get both conditions working for 1 alert. AV - BV = 200 AND AV + BV = 1000 I tried many options from the links and I kept getting errors when I put more than one condition. Thanks V Date Time Of Last Edit: 2016-05-24 13:06:57
